1959 oliver 880 carb problem
Sean
07-14-2001 22:56:04
Tractor was running fine,then all of a sudden it started chugging.Stopped it to check if there was any gas in it.There was gas coming out a screen on the air inlet side of the carb.Found alot of rust in the sediment bowl and gas tank.I had the tank cleaned and sealed.That solved the rust problem.Disassembled the carb.Cleaned it and rebuilt with all new parts except the float.Blew out gas line.Started up just fine,Then the stumbling started again.Shut it off.Gas was still leaking.Carburetor was very cold.85 degrees outside and the carb was about 50 to 55 degrees.Anybody experience similar problems?Anybody know how to fix it?Could it be that the float has sunk,or just needs readjustment?By the way it is a zenith cast iron carburetor.Help please!!!!
