1850 carberator
Brian
07-13-2001 21:04:47
I have another question on my 1965, 1850 gas. I am having a little trouble getting prelimanary adjustments on the carborator. It runs ok but it won't idle too well and it will not start again once it gets hot. Also when I have it under a working load,the governor will not keep the engine running at pto rpm. Obviously I need some adjustments but my operator's manual is a little vague on what to do.I also have a service manual but it isn't much help either. Does anyone have any ideas? Thanks Brian
ed
12-19-2001 18:59:38
 Re: 1850 carberator in reply to Brian, 07-13-2001 21:04:47
check your coil
BJW in NY
07-25-2001 20:40:14
i myself have an 1850 gas that was running very rough. i was told that the 1850 was so hard to get enough gas to it that they needed a gas pump to feed the carb because it could not pull enough through on vacum alone, somebody had pulled mine off long ago and could never keep it running right. my problem is tha they know leaned it out for so long that they burned out the valves and wrecked the cylinder walls. i would first check to see if you still have yours on and if it is still pumping. then i would start trying the carb , i have not got thatfar yet.good luck
