PTO on 1800C
B White
07-12-2001 18:53:32
I'm still working on the bugs on my 1800C. The PTO would not stop turning so I pulled the unit and took it apart. I have read before on this site that the clutch plates need to be flat. My friction plates are flat however my steel plates are all bowed somewhat like a dinner plate, curved from the center to the outside. Since all of them are like this I would like to know if they are supposed to have a bow in them, perhaps to provide a spring action for the engagement, or are they supposed to be perfectly flat? If they are supposed to be flat, I would need new
steel plates. Does anybody know of a good source? The local AGCO dealer prices the steel plates at $25 each and I need five. Also, is it necessary
to replace the friction plates as well, even if they are flat? Replacing those requires another 6 plates at $28 each. I don't use the PTO much,
just occasional brush hogging. Also, when I drained the final drive almost 14 gallons came out. The book calls for about 10 gallons. Is it likely the hydraulic system is leaking into the final drive? Thanks for your help.
yes no no yes
07-13-2001 05:08:45
 Re: PTO on 1800C in reply to B White, 07-12-2001 18:53:32
yes no no yes
