1855 pto
TLS
07-10-2001 08:26:24
Can't get pto to turn. Worked fine last fall when we quit useing it. Now when we move the control valve nothing happens. With valve in center position it turns easy by hand. Put in down position,(brake) some drag. Move to up position (pto) some slight drag. Same wether
it's turned forward or backward. When valve is turned on then off, oil flows through return line into resevoir. Have 175 lbs press on input line at control valve. Dealer said check linkage but that's ok. Any ideas?
Lee
07-10-2001 10:25:31
 Re: 1855 pto in reply to TLS, 07-10-2001 08:26:24
Lift rubber cap off of control valve,look and see if pin has fell out of the control arm.
