1850 Steering Stripped again
Danny
07-06-2001 20:08:56
I have stripped out the splines on the steering yoke again. Has anyone put a different axle under these tractors? I am looking for any advice at I Can Find.I really like this machine, it does all I need. What about an axle out of a late model something with slave cylinder type steering. Could it just be plumbed into the steering motor?
Or should I just forget all this replace the yoke and put some new stops on the spindles?
larry
07-07-2001 17:22:42
 Re: 1850 Steering Stripped again in reply to Danny, 07-06-2001 20:08:56
On one high hour problem front end i added a steering cylinder from a massy 510 combine. I cut the brakets off the combine too and welded everything onto the oliver and hooked up the hoses.It works great wish i had done it 10 years earlyer.
JIM
07-07-2001 15:38:49
IT SOUND LIKE YOU HAVE OTHER PROBLEM'S . ARE THE SPLINES OK ON THE BOX ? AND IF THE STOP'S AND SPINDLES .I WOULD START THERE .IWOULD THINK IT WOULD BE A THUOGH JOB TO PUT ADIFFERENT AXLE UNDER IT. GOOD LUCK . JIM
Danny
07-08-2001 05:57:43
 Re: Re: 1850 Steering Stripped again in reply to JIM, 07-07-2001 15:38:49
Thanks Guys I Will Look at the stops.And consider adding a cylinder.
