What model Oliver do I have?
Page Nelson
07-04-2001 09:55:23
I picked up an old Oliver and don't know what model it is. The ser # is 78448-873, and the "specification # is 48-1532, These numbers were on a plate below the gages. I found a number on the left side of the engine near the starter, (190320-K) below that was IKA-100E and below that was 1209. IT has a six cyl engine and the spark plugs are Champion D-16. The rear axels say rowcrop and the front end is a tricycle with two wheels Rear tire size 15.5-38 on 16" rim, front tire 6.5-16. I don't think the tire are orig. Any help would be appreciated.
Mark
07-04-2001 13:03:01
 Re: What model Oliver do I have? in reply to Page Nelson, 07-04-2001 09:55:23
Page, Your tractor is an 1959 880. Rear tires were 15.5x38 and the front tires were 6.00x16.
KELLY BLACKWELL
04-14-2003 16:59:30
 Re: Re: What model Oliver do I have? in reply to Mark, 07-04-2001 13:03:01
I HAVE AN OLIVER TRACTOR WITH NO SERIAL # WHAT SO EVER. I KNOW THE MOTOR # IS 190320E . THE CLUTCH PEDAL HAS THE # 1K-898-A. REAR AXLE HAS OLIVER ROW CROP ON IT. IT USED TO BE LP , KNOW ITS GAS. THE FRONT WHEELS ARE WIDE AND THEY ARE 6.50X16 AND THE REAR WHEEL IS A 13X38 . IT HAS 2 HOLES IN THE FRAME UNDER THE MOTOR ,ABOUT 3" INCHES IN DIAMETER . ONE ON BOTH SIDES , TOLD THEY WERE FOR EMPLEMENTS. PLEASE HELP, THANK YOU
