88770 Will wide front fit ???
Hank
07-02-2001 22:25:51
Will a adjustable wide front end off a 1950 88 Oliver bolt onto a 770 Oliver? Thanks
B A Star
07-03-2001 20:55:01
 Re: 88770 Will wide front fit ??? in reply to Hank, 07-02-2001 22:25:51
Larry is correct the adjustable front axle will bolt up to the frame, however, you may have steering problems. All 88 tractors had manual steering, thus the axle will have a manual steering box in it. If your 770 is an early one with the old gemmer steering, you have the steering shaft going all the way to the front of the tractor. If it is a late one it has hydrastatic steering, the shaft just goes into the steering control motor below the dash.
larry
07-03-2001 09:20:35
Yes it will bolt up.
