Power booster won,t shift
jerry Gerthofer
07-02-2001 12:31:51
my power boost won,t shift. from high to low. every thing seams to be o.k. in there. clutches are not stuck. whats wrong????? ??
Lee
07-05-2001 08:09:34
 Re: power booster won,t shift in reply to jerry Gerthofer, 07-02-2001 12:31:51
If the tractor won't move in low side,and will pull it's self in the high side, chances are your low side clutch has went south on you.They are kind of pricey.
kraig
07-04-2001 15:54:22
look for something simple at first it could be worn linkage, maybe the for that actuates it is not getting all the qay into the unit. Also unhook the linkage next to the unit and operate the valve by hand to see of you can feel the detents, and run it in either position to verify if the linkage going up to the operators area is not sticking. Change the filter if there is on. I hope you mean the over/under auxilary drive on an oliver tractor, if not forget this.
