1650 crankcam
Joe Dier
06-30-2001 21:34:36
Does anybody know if I could take a crank out of a bigger oliver (1800) and put it in my 1650 engine?
dave2_85
07-01-2001 13:50:52
 Re: 1650 crankcam in reply to Joe Dier, 06-30-2001 21:34:36
Depends on whether it is gas or diesel you have. The crank is the heart of the engine, so I'd be real careful about using anything other than the right factory spec part. The 1650 gas was 265 CID, the 1650 diesel was 283 CID with the same bore and stroke as the 1800C gas. A lot of times even when the bore and stroke are the same and the blocks appeared so, the diesel cranks had different metallurgy, heat treating, etc, because diesel operation puts much greater loads on the crank. You might be able to put a diesel crank into a gas motor if all the dimensions and clearances match but i 'd be real leery about a gas crank into a diesel. Better to use the proper crank to begin with. As long as you have torn into the engine and am putting that kind of effort and money into it, i'd spring for the right crank. good luck
