Own a Cockshutt 35 ??? I COULD USE YOUR HELP !!!!!
Alberta Mike
06-25-2001 13:41:01
If you own a Cockshutt 35, I could sure use some help if you don't mind crawling under the rear half of your tractor. I need the casting number off the iron casting which activates the clamping brake shoes. It is the cast iron part which is activated by the rod from the brake pedal. I believe it has machined shafts attatched to it (one for each shoe). If you can help me out, I would sure appreciate it. Thanks.
Mike M (WA)
06-27-2001 08:35:45
 Re: Own a Cockshutt 35 ??? I COULD USE YOUR HELP !!!!! in reply to Alberta Mike, 06-25-2001 13:41:01
Mike- I have a 35, and if it ever quits raining, I'll crawl under it and post casting numbers-
Mike
