Serial and Model Numbers for an 1855 ??
Ed
06-24-2001 06:24:17
I have an 1885 oliver. The tag on the tractor at the base of the steering colum says the serial number is " 229 982 - 685". My guess is the the tractor is a 1971, I don't understand the last three numbers. The tag also say's the model number is " 585-22755 ". Can anyone explain what this number means ???? I have three Oliver refrance books, and still no clue.
B A Star
06-24-2001 23:19:35
 Re: Serial and Model Numbers for an 1855 ?? in reply to Ed, 06-24-2001 06:24:17
Ed : As Dave posted, the first 6 digits in the serial number is the serial number of your tractor in production sequence. It was built in 1971. The last three digits tell us that indeed, serial number 229 928 was a 1855 with a regular speed transmission and final drive. As for the model number, 585-22755, the 585 again is a regular speed transmission and final drive for a 1855. 1st digit behind the dash tells us that it left the factory with an adjustable wide front axle, 2nd tells us that it had a diesel engine. The third (7) ididcates it was a forklift tractor, however, I don't think the 1855 was produced as a forklift! Perhaps you have misread the number or it was stamped incorrectly. I don't remember what the last two digits stood for. Hope this helps.
Chris Losey
06-26-2001 10:12:41
 Re: Re: Serial and Model Numbers for an 1855 ?? in reply to B A Star, 06-24-2001 23:19:35
BA Star,
My book confirms what yours says too. Maybe for some crazy reason, the dash pedestal was broken , and a used one was was put on, changing the serial number tag. Just a thought.
Want to sell that roll bar and canopy? I'd like to have a few original ones for some of my Olivers.
Ed
06-27-2001 04:42:35
 Re: Re: Re: Serial and Model Numbers for an 1855 ?? in reply to Chris Losey, 06-26-2001 10:12:41
That's a point I didn't think of Chris, thanks. On the ROPS, I'm keeping it. I'm looking for another for my Uncle's 2150 Oliver, and what I have found out is that it is going to cost from $600 to $1800 depending on the salvage yard, and as long as two years on the waiting list. Still looking.
Ed
06-25-2001 16:47:57
B A Star,
The tractor as I bought it four years ago at a local auction, is a Four Wheel Drive with a ROPS and conopy that has the Oliver Decal. Do you have a book that referances the Model Numbers ?? I would Like to find a 1655 with a high speed gear, and did not want to buy the wroung thing. I greatly appreciate the information BA Star. Thanks, Ed.
B A Star
06-25-2001 20:33:26
 Re: Re: Re: Serial and Model Numbers for an 1855 ?? in reply to Ed, 06-25-2001 16:47:57
That's interesting, If the tractor left the factory as a AG 4WD, the first number after the dash should have been 8 in the model number. Someone must have convereted it. A 2WD tractor has a short pinion shaft. A 4WD needs the longer pinion shaft to drive the transfer case. Does it have a speedometer? The Speedometer was driven off of the end of pinion shaft on a 2WD, and was driven off the transfer case countershaft on a 4WD. The tractor could have been ordered with the long pinion shaft, however, it would not have had a speedometer without the transfer case setup.
Ed
06-27-2001 04:46:19
 Re: Re: Re: Re: Serial and Model Numbers for an 1855 ?? in reply to B A Star, 06-25-2001 20:33:26
It has a speedometer, and the cable goes to the four wheel drive transfer case. I will take some pictures this weekend of the ID tag and tractor to see what you think. Thanks for the information.
dave2_85
06-24-2001 10:25:08
According to the number sequence in Gay's "Guide to Hart-Parr, Oliver, and White Farm Tractors1901-1996", 229-982 (the first six digits of your serial number) corresponds to the year 1971. My White had a similar thing, a nine digit serial number, 282-235-408, where the first six digits fits into the numbering scheme for 1978. I dont know what the other numbers are for, but deduced that the first six were the serial numbers since they were the only ones that fit into the serial number lists and the date they gave me fits with the known build dates for that type of tractor. Hope this helps.
