Steering column bearing
Grove r
06-23-2001 23:35:01
Hi, everyone, my first post on this board. have a question for someone with a parts book for a 55 Oliver tractor. need to know the no. on the bottom bearing on the stearing shaft, the one inside the steering box. Now the hard part, this tractor belongs to my brother, there is no decals left to tell us if it is truly a 55, but according to pictures I have seen, believe this is what he has. The steering set up is very much like the Ford and Ferguson, with two drag links, one from either side of the steering box. A bearing no. would be even better, so he could pick one up from the local bearing shop, [we don't have a White dealership in our area]. Thanking you very much for your time and response, have a gooder R.E.L.
Jake
06-24-2001 20:48:57
 Re: Steering column bearing in reply to Grove r, 06-23-2001 23:35:01
To check the model of the tractor get the number from the plate by the break pedal. 55's are usually for instance 47450-518[a 57 yr] The other is a spec no which has no bearing on parts etc. With this info the tractors model, year etc can be found on ths site.
Delbert
06-24-2001 18:34:36
The numbers you are looking for are cone,Steering Gear Worm Thrust Bearing 1L-6769, Cup Steering Gear Worm Thrust Bearing 1L-6770. There is a Retainer, Steering Gear Bearing Assembly 1E-6824 and an Eyelet Steering Gear Bearing Retainer Flange 1E-6825, these last two pieces go in the bottum and you may not need them. The top bearing is the same as the bottum bearing. I pitched the boxes the bearings came in from the bearing company so can't give you those numbers. If you have a Ford or Ferguson dealer try there as I have been told by a Ford owner they are the same. When I bought mine from a bearing company it killed a 100 dollar bill for the bearings. The bearings are not tapered, they are a barrel shaped rollers. If your tractor is like mine was the top bearing ,dirt shield and the steering wheel were bad and let water in and rusted out the bearings. If you need those numbers e-mail me or post something on the Discussion board. Delbert.
Grove r
06-24-2001 22:57:28
 Re: Re: Steering column bearing in reply to Delbert, 06-24-2001 18:34:36
Thank you Jake and Delbert, this is the information I was hoping for, now we have something concrete to go on. I will hang on to your e-mail address in case we run into any more difficulties, have a gooder, R.E.L.
