Oliver 770 power stearing problems(results)
Scott Green
06-20-2001 15:08:19
Jim , You said that the power steering system may be air bound. I think you were right. I jacked the front end up off the ground. Then turned the steering wheel all the way to the left , and then all the way to the right. I did that 3 or 4 times. My power steering seems to be back to normal. That's one little trick I won't forget. Thanks , Scott
