Removing PTO shaft on a 1950.
J T
06-20-2001 12:38:25
I have a 1950 GM need to remove the pto shaft to remove the engine I looked in the book and it said something about a puller needed to remove the shaft. What can I use to substitute for this and does the main shaft pull out without removing the entire assembly? Thanks John Mann
Bill
06-20-2001 14:27:38
 Re: Removing PTO shaft on a 1950. in reply to J T, 06-20-2001 12:38:25
If the tractor has a pto, there is a snap ring, a plug, an oring and a then the long shaft. I think the threads are either 1/2 inch or 5/8 course in the end of the plug and long shaft. You can use a threaded rod to remove it. The only thing that you need to remember is to remove the oring that is inside where the plug is. some people forget and you cannot remove the shaft without the oring out.
MikeO
06-20-2001 21:21:31
 Re: Re: Removing PTO shaft on a 1950. in reply to Bill, 06-20-2001 14:27:38
I made a tool using a 1/2 inch diameter rod with standard threads on one end. I then welded an L shaped rod to the unthreaded end. The L handle lets me turn the rod in and out while it gives me leverage for pulling or installing the shaft. I also agree with Bill on the o-ring removal. On one recently acquired 1855, I found the o-ring with teeth or grooves cut in it. Apparently someone didn't know about removing it and used a pretty good amount of force to get the shaft in and out.
