Oliver 66 questions
Zonie
06-20-2001 00:28:34
I've located a 1955 Oliver 66 diesel for sale and am told it runs but needs injector pump work. I assume that means it needs the pump rebuilt and probably the injectors also. this tractor is susposed to have a cracked cylinder wall also.
I'm wondering about the cost of rebuild on the pump and injectors.
Does this tractor have sleeves or does it mean I'd have to have the block sleeved to repair the cracked cyl.?
Does the 66 have live pto and hydraulics?
I own a Farmall H tractor and know next to nothing about Olivers.
Any Ideas of what this tractor is worth?
B A Star
06-20-2001 09:33:18
 Re: Oliver 66 questions in reply to Zonie, 06-20-2001 00:28:34
If the tractor is a 1955, it is a Super 66. Does the front frame have square mounting pads with four tapped holes in the mounting pads? If it does it is a Super 66. Either model, 66 or Super 66 have live PTO and hydraulics. Engine has wet sleeves. Injection pumps and nozzles are expensive to repair, a rebuild would cost at least $1200 if the pump needs a new hydraulic head. Either model is a neat little tractor that is easy to handle, diesels are not real common especially with the wide adjustable front axle.
DKaiser
06-21-2001 12:41:45
 Re: Re: Oliver 66 questions in reply to B A Star, 06-20-2001 09:33:18
When we redid ours they told us you can't get the pump heads or those pumps. From the way it sounded you can't get pump heads for any or the oliver diesel injection pumps.
