Replace JD 2440 with Oliver ??
normag
06-18-2001 15:58:29
Thinking of selling our $13000 JD 2440 and buying a less expensive all around tractor. What's your thoughts on getting a Oliver 1600 ? 1650? 1500 or 1550 ? Would still like a loader on the replacement tractor. Some people say the Oliver front axle breaks. Was the 1650 improved ? Given same condition, is the Oliver diesel or gas a better engine (not concerned with fuel economy, mainly with reliability, parts, and starting in Wisconsin). use for 14' wheel disk, 3x16 plow, rear box blade, 3pt mounted 6 chisel plow, 24" posthole auger, 7' rot mower.
Nate Gray
06-18-2001 19:44:56
 Re: replace JD 2440 with Oliver ?? in reply to normag, 06-18-2001 15:58:29
If I were you I would go with the 55 series. They are really nice tractors and you will get to appreciate the 3-way torque. The old diesel Ollies were generally hard starting, but a block heater or a little touch of ether will do the trick. One of the main problems that plaqued the Olivers was the Waukesha engine. They didn't have the cooling capacity that they really needed and you have to be carefull when really working them. Overall the Olivers are great tractors, I wouldn't own anything but them.
thanks
06-24-2001 21:51:19
 Re: Re: replace JD 2440 with Oliver ?? in reply to Nate Gray, 06-18-2001 19:44:56
