Cab wheel wieghts be swapped from S-55 to 550?
ShepFL
06-18-2001 09:49:00
Have a chance to buy some rear wheel weights and curious if wheel weights are compatible. My parts manual suggests that most 550 wheel weights were for Power Adjust Rims, which I don't have.
Here is wheel weight info -
Each is 19 3/4" across (outside to outside) with a center hole of 10 3/4". They have 4 bolt holes which measure 15 1/4" across the rim and 10 3/4" from hole to hole along the outside. They are 5" tall, which includes a 2 1/2" beveled edge and 2 1/2" of cone on the top. They weigh out at 100 pounds each.
Here is 550 rear wheel info -
Tires I have mounted are 14.9x26 Harvester Kings
Diagnol spacing center to center on most inner bolt holes of rim is 3"
Distance across rim center to center on most inner bolt holes of rim is 8"
Diagnol spacing center to center on center bolt holes of rim is ~11.5" (suspect this is where weights bolt on)
Distance across rim center to center on center bolt holes of rim is ~15" to 15.5" (suspect this is where weights bolt on)
Diagnol spacing center to center on most outer bolt holes of rim is 12"
Distance across rim center to center on most outer bolt holes of rim is 24"
Thanks for your experience
Larry
06-18-2001 17:49:55
 Re: Cab wheel wieghts be swapped from S-55 to 550? in reply to ShepFL, 06-18-2001 09:49:00
As a general rule oliver wieghts can be swapped if the rim diameter are the same.I have a book that has all the weight info in it.I will try to find it.
Thanks Larry - (ShepFL)
06-18-2001 18:48:47
 Re: Re: Cab wheel wieghts be swapped from S-55 to 550? in reply to Larry, 06-18-2001 17:49:55
My parts book just lists alot of Power Adjust info. Also, are part #'s same as casting #s on the wheel weights?
Larry
06-19-2001 08:38:07
 Re: Re: Re: Cab wheel wieghts be swapped from S-55 to 550? in reply to Thanks Larry - (ShepFL), 06-18-2001 18:48:47
My book shows the poweradjust wieghts as differant from regular rims.They evan seem to have differant numbering system on them.One wieghts 75lbs the other 110.
