Broken injector on 1855
MikeO
06-16-2001 18:54:48
Our oldest 1855 was running rough and we finally got to pulling the injectors to have them tested. When we removed the return fuel lines, we found our #3 injector was broken off. The small outlet tube and nut were gone. Has anyone see this before and if they did, was there something else that needs to be checked out, ie possible damage to injector pump. Thanks in advance.
Larry
06-17-2001 09:41:42
 Re: Broken injector on 1855 in reply to MikeO, 06-16-2001 18:54:48
The return lines return to the tank not the injector pump.The pump has a bleed off line too which is connected to all the others,but they all flow towards the tank.Hopefully the line is not blocked now by the missing parts.
