Oil leak in 770
Jake in NY
06-10-2001 20:50:42
I noticed an oil leak from the underside of our 1966 770 a few days ago. It is currently packing the silo and the increased workload seems to have busted loose the leak from a drip to a downpour. I keep checking the oil and have added maybe a quart a day but the leak seems pretty fast to only lose a quart. It only leaks when the tractor is running.
We're thinking rear seal. Now, the big question is, how difficult would this be to fix/replace? Do we have to break the tractor in half to get at it? There is no hydro shift or anything like that. Just a plain old 6 speed transmission. We're also going to replace the clutch while we're in there.
Thanks, Jake
chief613
06-11-2001 15:54:07
 Re: oil leak in 770 in reply to Jake in NY, 06-10-2001 20:50:42
i had similar leak on mine and found it to just be the oil pan gasket.
larry Wolfe
06-11-2001 09:17:11
You don't have to split the tractor.Olivers where desinged so the parts will colapse and move back so all clutch and oil seal parts can be easily replaced.You do have to remove the pto drive shaft that goes to the flywheel.You can evan leave the fuel tank on.
