Oc-12 crawler, help
jeff
06-10-2001 17:47:40
i know this isn't the crawler group, but there
isn't much oc-12 discussuion in the other group.
i found an oc-12 diesel. price $700 everthing is there, suppose to have rebuilt
injector pump, valves ground and reset. has a 10'
blade. now the bad, tracks look really worn
haven't heard it run but says the governor needs
wore in cause its sticky from sitting.
how big a money pit am i digging? more important
how easy is it to work on? tranny? clutch? steering? and if i get it fixed up how good a unit
do i have when i'm done? i have an oc-6 gas
and love it.
thanx for the help jeff
Dianne
06-11-2001 07:31:17
 Re: oc-12 crawler, help in reply to jeff, 06-10-2001 17:47:40
Since nobody else has thrown in a comment, I will.
I just rebuilt an OC-46-3G (#12 off the assembly line) from the ground up. The rails were acceptable (about 50%), pins & bushings cost me $500 U.S., presswork was a deal at $640 (CDN). Engine machining and rebuild parts, $2000 (CDN).
Doing all the work myself (except press and engine machining) I ended up with $8500 in to a machine that started out as a free-bee.
jeff
06-12-2001 18:44:24
 Re: Re: oc-12 crawler, help in reply to Dianne, 06-11-2001 07:31:17
thanx dianne,
i really not sure what i'm going to do.
i hate to see it go to the junk yard though.
i guess not too many others are interested
in the large crawlers.think i'll call landis
and see what he says. thanx again, jeff
