PLuged water jacket
larry
06-10-2001 16:58:00
How do i get the water and stuff( rusty gue) out of an engine when nothing will run threw the water jaket.I have been digging with a wire and blowing with air preasure.There is water at the top (water pump) but it wont run out the bottem.
ferrell
06-11-2001 13:39:01
 Re: PLuged water jacket in reply to larry, 06-10-2001 16:58:00
There is that much rust you, need to remove the block and boil the rust out of the block. If you have a tank big enough to cover the whole block in liquid ,get four to five cans of red devil lye. Remove all cylinders liners, crankshaft,camshaft ,gears freeze plugs . Place the block in the tank add red devil lye then carefully add the water . Make sure you have saftey glasses good rubber gloves on . This will do the same as a boiling one out.
Dean
06-10-2001 19:05:41
Many machine shops, engine builders, and even some larger auto parts stores can "hot-tank" the block for you.
larry
06-11-2001 09:19:05
 Re: Re: PLuged water jacket in reply to Dean, 06-10-2001 19:05:41
The engine is still in the tractor.Would a steam cleaner blow that stuff out?
Dean
06-11-2001 10:45:53
 Re: Re: Re: PLuged water jacket in reply to larry, 06-11-2001 09:19:05
If the water jacket is that plugged it's that plugged all over. If you don't hot-tank it, you'll end up with the engine overheating, possibly destroying it.
larry
06-12-2001 08:59:49
 Re: Re: Re: Re: PLuged water jacket in reply to Dean, 06-11-2001 10:45:53
I hooked an air coupler to the blook drain.When the hose is on it boils some air out the top.Then when its removed nothing runs out the hole.
