Constant flow hydraulics
Jake in NY
06-03-2001 19:29:37
We have a bale wrapper which requires constant flow hydraulics and we're not sure which of our Olivers has it. We have a 1650, 1655, and a 1955.
Jake
Shep
06-04-2001 06:04:33
 Re: constant flow hydraulics in reply to Jake in NY, 06-03-2001 19:29:37
I have a bale wrapper too and any of them will run it, I just lock the remote handle in place with a strap in the direction that I want and it works fine. A note -- the 1650 and 1655 are an open center hydro system and the wrapper must be set that way, the 1955 is a closed center system and you must change the valve spool on the wrapper if you are going to use that tractor. You will not have to strap the 1955's remote lever, as it will constant flow by just moving the lever. DO NOT change to the 1955 until the wrapper is set to closed center or you will ruin the valve in the wrapper.
Find out if the wrapper is set to run open center or closed center before you run it and use the correct tractor. Personally I would use one of the 16's because of the size. Mine is a trailer wrapper and it works good to the 1655.
Nate Gray
06-03-2001 19:45:36
My cousin has a 1655 and a 1955 and they both have constant flow hydraulics, so I imagine yours would too. You have to be careful though, because on his only one side is constant flow. On the 1655 it is the left side outlets.
Nate
