2-70 white
Tim
05-31-2001 16:21:43
I looked at a 2-70 white today that has not run
in a year. It needs a over and under rebuld and
probably an engine rebuild to. Does any one Know
about what that would cost and what is this tractor worth. It has good sheet metal and looks
pretty good from the outside but it has several
other problems. thanks
Hal
06-02-2001 13:07:09
 Re: 2-70 white in reply to Tim, 05-31-2001 16:21:43
These are solid tractors, same as a 1655 and probably one of the most reliable Oliver's made. If they are well maintained and not abused the 283 engine should be good for way more than 5000 hours before rebuild. But when things break, parts (especially those available only via Agco) can be expensive. Example hydraulic pump, maybe $700-800 Agco, or $400 aftermarket, then you need the gaskets etc from Agco, it can add up fast. I can imagine things like power steering, over/under etc. If you are buying, check out the systems and make appropriate deductions from price. If the over/under runs ok in under or direct you could probably use it like that for a long time. Good luck.
