Super 99 GM?
Scott
05-29-2001 12:28:07
Although Oliver started making the Super 99 with the 6 cylinder engine in 1954 they did not put the GM engine in the Super 99 until about the middle of 1955. The Nebraska test tractor was probably one of the first Super 99 GM's made and it was serial number 520197. Does anybody know the serial number of the very first Super 99 with the GM engine? What is the lowest serial number of a Super 99 GM you are aware of? Thanks!
dave
05-29-2001 18:34:47
 Re: Super 99 GM? in reply to Scott, 05-29-2001 12:28:07
From what I can see, the serial numbers of the Super 99 and the Super 99GM are melded together in a common block starting at 519300-519675 in 1954. 519676 to 520455 in 1955 to 520456 to 520493 in 1956 to 520944 to 521612 in 1957 and finally to 521613 to 521635 in 1958. The magnificent Franklin Mint Super 99GM model is so detailed that you can read the serial number on the builder's plate and it is 521009, which would make it a 1957 build. This model is so realistic that you can practically hear the ol GM scream.
hope this is of help.
question quality
05-29-2001 20:06:22
 Re: Re: Super 99 GM? in reply to dave, 05-29-2001 18:34:47
If it is so authenitic, wouldn't it show more oil leaking on the outside?
dave
06-03-2001 17:15:04
 Re: Re: Re: Super 99 GM? in reply to question quality, 05-29-2001 20:06:22
good point, either a brand-newly painted concours model, or i'll have to add some simulated oil for that, to simulate a leak. It may need diapers but then there is no more reliable and rugged diesel than the ol' 2-cycle "Jemmy" GM. And this is from a Perkins/Cummins man.
J T
05-31-2001 19:55:43
Sure the gm oliver leaked a little oil but I have to wonder why someone would critisize such a nice model tractor and even the real machine. I pwn one of the models and a 990 with the gm .Also have a 1950 gm has abundance of power. Let's remember that detriot engines were in a lot of the old trucks hauling cummins and cat parts around, give some credit where it is due. Also these engines leaked primarily because blower box drains would become clogged and presurize the crankcase also they would run very high hours needing an overhaul , having blow by causing leaks. I have one that has 14000 hrs on it , yes it leaks but does a good job still.
John
06-21-2001 17:01:21
 Re: Re: Re: Re: Super 99 GM? in reply to J T, 05-31-2001 19:55:43
I have read of a GM 3-71 engine and a Detroit 3-71 engine. Is this one in the same?
