Weight of an 88
Jerry B
05-29-2001 06:32:46
I have an 88 RC, nf, with cast centers front and rear. It also has the extra circular wheel weights on the inside of the rears.
How much does this tractor weigh? How much do the cast centers on the rear weigh?
And how much do the circular weights weigh?
The reason I am asking is because I am trying to get this thing ready to pull by this week end and I don't want to show up so grossly over weight that I am in the higher weight classes.
Thanks guys.
MAK
05-29-2001 19:44:46
 Re: Weight of an 88 in reply to Jerry B, 05-29-2001 06:32:46
I have a gas and diesel 88 that I pull. The Gas 88 with heavy centers weighs about 4800lbs without hydraulics which would be about another 150. I have the light front hubs (75lbs each-cast hubs)on the front which would make yours weigh about 5100 . The wheel weights come in two different weights. One is about 2 inches in O.D, smaller than the other. They weigh about 115-125 each. If you have fluid in your tires, your tractor could easily weigh at or above 6,000 lbs. The heaviest weight class I ever pulled my diesel (140Hp) in was the 14,000 lbs class on an easy pulling track(got second). The ideal classes for you to pull with a stock 88 would be anywhere from 5,500-7,500lbs. By the way, if it is a super 88 it will weigh about 100lbs heavier and a diesel will add about another 100lbs. Good luck at your pull. I hope I didn't over whelm you.
Jerry B
05-30-2001 05:44:30
 Re: Re: Weight of an 88 in reply to MAK, 05-29-2001 19:44:46
Thank you for your quick responce.
My 88 is gas powered,has no hydraulics, pto, or belt pulley drive assembley, nor fluid in tires.
Judging from your numbers and those of Jim T, my best guesstimate is about 5240 lbs. I will add wheely bars later this week and careful weighing of them should tell me how much more to add to this figure.
Like Jim T said, I need to get it weighed and know for sure.
Now where did I put that scale?????
Jim T
05-29-2001 19:19:42
Not sure of the weight of an 88 because of variables, fluid in tires,etc. I do know the rear weights on my 88 are 143# each because I weighed them. You need to go to a scale and just weigh it. Lots of luck pulling! JT
