Super 55 PTO,Inop
Bootss
05-22-2001 07:03:08
Help? My PTO does not turn on my Super 55.I have removed the top case cover and see nothing wrong.I really need a bit of working knowledge of the Pto system if anyone can help?Also the hi-lo lever to the right side seems to be not working(very loose front to back)and linkage is hooked up.Just bought a woods mower deck and can't use it,thanks.If possible please email as the grass is getting tall. Paul
Paul Stanley
05-22-2001 13:44:36
 Re: Super 55 PTO,Inop in reply to Bootss, 05-22-2001 07:03:08
Go to the link for some help, but Dennis is right, buy the manual. At least, it will teach you how to engage your PTO. Make sure you engage it slowly and let it snap itself into position. The early models did not have a lock, the later ones have to release by pushing down.
Mike M (WA)
05-22-2001 09:16:38
You mention the hi-lo lever on the right being loose and not working- To the best of my knowledge, the Super 55's did not have a hi-lo feature. The long lever to the right of the seat is the PTO engagement lever- you push down (vertically) on the knob, and push the lever back to engage the PTO (it should snap into position- if it doesn't, you have to remove the inspection plate underneath the tractor and adjust the wheel- it has a pin you push in, then turn the wheel to put more tension on the clutch linkage so lever snaps into position).
larry Wolfe
05-22-2001 09:15:24
The pto chutch is in front of the transmission sort of under the main clutch.There is allso external linkage from the lever up to the clutch pivot shaft,This can break or a key shear or pin come out.Check this and the access plate under the center of tractor first.If you have the hydrolic unit off might as well rebuild it all includeing the pump.The linkage adjustment on the linkage has several steps, you need a manuel to do it all correct.
Dennis(CA)
05-22-2001 07:36:15
You need to get a manual for your 55. The inspection plate for the pto is underneath the tractor. You can adjust the pto clutch by turning the gear. You have to depress a pin while adjusting the clutch. Again, buy a manual.
