550-oil for three point
louis
05-20-2001 05:58:05
How do i drain the oil from the three point(which drain plug)I have been told to use a mixture of ATF and Hyd good/bad?
Jim Kuczynski
06-20-2001 07:09:30
 Re: 550-oil for three point in reply to louis, 05-20-2001 05:58:05
The recommended fluid for your hydraulic system would be Coastal AW68. It's good for all temperatures and can be found at most Ag supply stores. See //www.ransomgroup.com/coastal/tractor.html for more info.
If you instead decide to use motor oil, use ONLY non-detergent type to prevent foaming.
If you want to do the job right, use the AW68 AND replace the filter.
Jim
Jim Kuczynski
06-20-2001 07:09:02
Jim
Larry
05-20-2001 13:47:38
You have to pump the oil out,just remove the raised plug in the right front.
Leo
05-20-2001 09:34:42
Check your book, but I believe 30 weight oil is what is suggested. It works well for me.
Paul STanley
05-20-2001 09:56:57
 Re: Re: 550-oil for three point in reply to Leo, 05-20-2001 09:34:42
10 weight below 32� 30 weight above or use 10W 30 all year.
