1850 hi low slips
jmc
05-19-2001 03:57:44
a frend of mine has an 1850 and he says it seems like the hi low slips.is it hard to rebuild this?is it just a clutch pack,can it be adjusted?
larry
05-19-2001 16:05:29
 Re: 1850 hi low slips in reply to jmc, 05-19-2001 03:57:44
They are hard to get out but not so hard if you have a book.The two speeds only have a direct clutch(hydrolic piston),they can carbon up and stick or the main spring can break.Low speed is a over running clutch(spragg with offset rollers).First thing to do is flush out the unit after draining the fluid.Change the filter and put in new oil.On an 1850 you can allso remove and clean the two relief valves without removeing the engine,they both can stick or break springs.Allso you can preasure test the systems and try to diagonse whats wrong before removal.
