Old 88 sheet metal
puller
05-09-2001 08:42:32
I just got a 88 Oliver in that is a pulling tractor. It has been made from parts. The old fart that had it, had his own 88 junkyard. The sheet metal is different than any other 88 that I have seen. The grill looks like the grill from a old 66. I have already had two guys try to buy the hood and grill.
What do I have? I'm not a Oliver collector or puller.
Thanks
davem
05-09-2001 09:57:39
 Re: old 88 sheet metal in reply to puller, 05-09-2001 08:42:32
What you have is the original sheet metal for the first 88's,it looked like an 80.If your serial number bares that out you have got a very collectable Olie
dkaiser
05-09-2001 15:57:53
 Re: Re: old 88 sheet metal in reply to davem, 05-09-2001 09:57:39
The first 88's built in 47 and 48 used sheet metal similar to the 70 and 60, not the 80. As far as i know the 80's were all unstyled. If you look at it the hood and the dash should be similar to the newer 88's, but the front end is different, that looks like the older tractors. Now I can't tell you how similar the hood is to the newer style, but be careful because the dash is different from the newer tractors. We bought a '48 old style 88 recently and they seem to be good property to have.
