60 Std or Industrial ??
Erik H.
05-06-2001 15:09:16
I bought a 60 Std for parts to build up one I
had. I was told it had a snowplow on it, and I
saw 2 mounting pads on each side of the frame and
thought nothing of it. The serial number on the
motor tag reads 410525, just a 1944 Standard.
It is painted blue with white wheels, however
there are many spots of yellow or faded orange
under it. Did Oliver stamp the serial # on the frame?
The mtg pads are factory, not cobbed on. Altough the motor is stuck and a bad crank,
I would hate to part out such a rare tractor, if
it really is an Industrial. Can anyone shed some light on this matter?
Jerry B
05-07-2001 06:34:26
 Re: 60 Std or Industrial ?? in reply to Erik H., 05-06-2001 15:09:16
uh..sounds like just a piece of junk iron to me. I will come and haul it away for you a few dollars..... ;)
B A Star
05-07-2001 00:06:31
Your description of the tractor makes it an Industrial as they had the pads on the frame where the Standard did not. Appearantly someone has changed the engine and installed one out of a Standard as the serial number fits the Std. There were 815 Industrials built from 46 to 48. I have a 48 that was a highway mower tractor for the state of Kansas, painted a light blue when I got it. The transmission has a casting date in raised numerals on the bottom side towards the left hand side. That may give you some idea of when it was built.
