Decal Placement....
Tim Imrick
05-06-2001 06:25:23
Does anyone have a chart I could use for placement of some decals for an 88 RC ??
I know where the Row Crop 88's, the Diesel Power, and the 88 go..... but that's it...
I got two for the Air Cleaner ( ? I think ), One that says, "Warning Shields are in place for your Safety" ( That goes on the PTO ?) There's a bigger Yellow sticker that I think goes next to the Row Crop 88 ?? or for the fender?? And there's one more that says "Drain here and at Radiator" ???
Any help would be appreciated..
-Tim
Jack
05-14-2001 18:11:52
 Re: Decal Placement.... in reply to Tim Imrick, 05-06-2001 06:25:23
I did a RC77 last year and had the same questions. If you can get a operators manual and look carfully at all the pictures you can get the placment.
I hope this helps.
Jack
MCL in IN
05-06-2001 14:19:58
See if I can help. I think there is an air cleaner decal that says oil level. It goes on the cleaner bowl that holds the oil. There are some markings on the bowl--place accordingly. The other decal goes up on the body of the cleaner. The safety decal goes on the PTO shield. I don't know if they had these originally but I am sure the lawsuit people require it in the kit. The square yellow decal goes on the left (I think) fender. I get on and off on the left so I put mine on the right so I won't rub it. There is an engine block drain toward the rear of the block. That is where the "Drain here" decal goes. Enjoy.
