Oliver 70 water pump, 60 cultivator, and steel wheels/belt pulley
FM
05-03-2001 06:43:28
First question: The water pump on my 70 is leaking. Any Ideas on how it can be fixed?
Q.#2: I know a guy with a cultivator off a 60. Will it fit on my 70? What is it worth? Must have been shedded, it is mostly still red.
Q.#3 The local Imp. dealer has a 70 with steel rear wheels and a belt pulley. They are about the only things worth anything on that tractor. The front rims are good, too.
rooster
05-05-2001 22:40:48
 Re: Oliver 70 water pump, 60 cultivator, and steel wheels/belt pulley in reply to FM, 05-03-2001 06:43:28
FM, where do you live?
Put a new gasket on your water pump housing, that should stop it from leaking.
FM
05-07-2001 05:53:44
 Re: Re: Oliver 70 water pump, 60 cultivator, and steel wheels/belt pulley in reply to rooster, 05-05-2001 22:40:48
Ohio...Why do you ask?
rooster
05-08-2001 02:09:24
 Re: Re: Re: Oliver 70 water pump, 60 cultivator, and steel wheels/belt pulley in reply to FM, 05-07-2001 05:53:44
Just wondering how far away you are. Is the 60 cultivator one that mounts on the tractor?
FM
05-08-2001 05:44:45
 Re: Re: Re: Re: Oliver 70 water pump, 60 cultivator, and steel wheels/belt pulley in reply to rooster, 05-08-2001 02:09:24
Yep.... I do believe I am going to buy it sometime this year.... soon as I get the water pump fixed on her..
