A96 Cleattrack, need reality check
dave k
05-01-2001 09:58:02
I have a chance to buy an A96 cleattrack for $800 from guy next door. Hydrualice work, engine did run, but he may have let it freeze last winter. Tracks OK but drive sprockets cracked. Track guides need replaced as do return rollers and lots of bushings. Have machine shop so some things I can fix. HAs log winch, but needs some work.
Thats what I know!
Would like to have dozer for weekend farm, vacation home type stuff, like clearing and road work and tree pulling. Will not use a lot, but when home I want to use it, not fix it. Can spend a couple years fixing up.
I would appreciate any comments on this project. I would like a dozer, but a more modern 6way blade job is just not in the budget.
thanks all
d
jerry Gerthofer
05-02-2001 10:52:17
 Re: A96 Cleattrack, need reality check in reply to dave k, 05-01-2001 09:58:02
yes thats about all it,s worth..... be prepared to put $5000.00 or more into it
Albert Duroe
05-02-2001 16:12:54
 Re: Re: A96 Cleattrack, need reality check in reply to jerry Gerthofer, 05-02-2001 10:52:17
I presume you are looking at an AG6 which has a continental 226 motor (very common also used in massy 44) Most of the used parts you would need I would have or Landis Zimmerman @717 7382573 I have also rebuilt an AG6 and could help you with questions.
