550 pto hickuping
Fred
04-29-2001 21:20:53
I have a box scraper on My 550 oliver desiel the thing is bouncing up and down like crazy if i dont have the thing all the way down if i put the lever at half way it hickups bad getting to be a real problem? i remmber seeing something about installing a clean filter and using non detergent gear oil? will this fix it or could it be something else?
Thanks...
Pete in Ks
04-30-2001 04:49:55
 Re: 550 pto hickuping in reply to Fred, 04-29-2001 21:20:53
Your problem is in the draft control. I had the same problem with a post auger. It started doing this when it hadn't before. I found the top link pin was tight and when I'd lift it would bounce. There is an adjustment to stop this action. Refere to your op. manual.
Fred
04-30-2001 22:26:20
 Re: Re: 550 pto hickuping in reply to Pete in Ks, 04-30-2001 04:49:55
Arg! I have the shp manule and i dont seem to see anything in there:-( any sugjestions?
Pete in ks
05-01-2001 06:19:46
 Re: Re: Re: 550 pto hickuping in reply to Fred, 04-30-2001 22:26:20
On the top link yoke is there two bolts in the back side that don't seem to do anything? Adjust them out to restrict yoke forward movement. That is how mine adjusts yours may be different but should be similar. My tractor is a first year run and later models probly had minor changes.
Fred
05-01-2001 19:15:05
 Re: Re: Re: Re: 550 pto hickuping in reply to Pete in ks, 05-01-2001 06:19:46
Thanks let me give it a look and see if i can find anything:-)
