Had 550 running
wolf
04-28-2001 12:58:00
Pull started it.At full throtle it would run about a thousand rpms. rechecked timing, is good.Just acts like not getting any fuel, not enough to reve up. Could have missed something in carb, don't think so,going to dump old gas,try new, maybe in govnor????? ????? ? basicaly at a loss at the moment. I Did shut it down four or five times while it was running, started right back up, not a problem. But would not reve up.Now it will not start again at all.Anyone want to make an offer for it? Believe it's a 1965 with a 588 front end loader, new battery and alt. rear tires fair,could use front tires.No grill due to front end loader.Fredericksburg,Va. 540-582-3951
Mike
05-22-2001 12:10:20
 Re: had 550 running in reply to wolf, 04-28-2001 12:58:00
I am interested in the 550. Is the bucket in good shape? Does the PTO operate? Thanks.
larry
04-28-2001 17:11:29
The govoner on these tractor can get worn and the parts outside will hook togather,this causes the govoner not to function.Usualy the tractor will rev up with a small move of the lever.You can see if the throttle moves or not,or has spring tension or solid.You live only 60 minets from me, southern md.I allredy have one of those.
wolf
04-28-2001 21:13:15
 Re: Re: had 550 running in reply to larry , 04-28-2001 17:11:29
will pull air cleaner and see what i can find, it looks to move ok from what i can see,book i have not the best.eng has only about 100hrs sense full rebulid.thanks wolf
larry
04-29-2001 08:57:30
 Re: Re: Re: had 550 running in reply to wolf, 04-28-2001 21:13:15
I doubt its the govner.I for got to say my last name is Wolfe.
