PTO Disengagement
KnuckleBuster
04-27-2001 16:34:19
Howdy Folks
Bought an Oliver 550 from an Auction house It has the long PTO lever on the right side with what looks to be the stop for the lever on the right side of the Hood not all the parts are there If I Pull the lever back too far the clutches in the clutch pack come out of the carrier or housing and become misaligned and will not go back into the carrier/housing until I align them back-up thru the inspection access Hole. I was wondering if anyone has had this same problem...My I.T. manual I got at Tractor Supply is nearly useless.....
Regards!!
Kerry
05-01-2001 06:07:46
 Re: PTO Disengagement in reply to KnuckleBuster, 04-27-2001 16:34:19
My 550 did this and it was a pin that holds the pto shaft together. It was a simple fix but I destroyed several pto disks before I realized what was going on. If it is the same problem as mine you will have to drain the transmisson oil and remove the pto shaft from the rear of the tractor and slide the shaft out and put a new 50 cent pin in it. It can be placed back in through the rear into the pto clutches by aligining through the hand hole cover in the bottom of the tractor. good luck
KnuckleBuster
05-04-2001 19:31:28
 Re: Re: PTO Disengagement in reply to Kerry, 05-01-2001 06:07:46
All right! sounds like the same problem I have had. Thanks for the input , I will check it out and post a response , I too have trashed several pto disks , Not cheap , and after replacing them I just wired the pto engagement handle down until I had time too figure this one out.....
Regards
Knuckles busted
jake
04-27-2001 20:33:55
Check the adjustment collar. If it is adjusted properly the discs are held inside the housing and cannot come out regardless of lever position so try to tighten the collar using screwdrivers to push lock in and tighten the collar. Good luck Levers available from www.wegners.com
