What to do with my tank
nmc
04-26-2001 20:30:17
My oliver 1600 stops running due to rust blocking the hole feeding the sediment bowl
anyone know how to get rid of the rust without buying a new tank?
Thanks
Chief Meckanik
05-17-2001 20:29:39
 Re: what to do with my tank in reply to nmc, 04-26-2001 20:30:17
Long ago and far away, I apprenticed under an old airplane mechanic, whose specialty was ragwing Pipers - the little cowl gas tanks are spendy when available, and so many have the same problem, he did a lot of fixing of tanks with rust scale and pinholes, etc.
He would take the tank out of the airframe, empty it out, flush with soapy water (lots of it)and dump a pint or so of gravel in it - them shake like a madman to scour out the scale, empty her out, rinse again and let dry a couple days in a warm dry place. Then he would blow it out real well with compressed air. Put a plug in the supply line fitting, using some teflon tape or pipe dope to keep the threads clear. Then pour in a quart of Pliobond industrial contact cement, and slowly rotate the tank to completely coat the innards, finishing up by inverting it to allow the excess to drain out the filler neck.
Personally, I would first try a sample tin can and test it out with today's fuels - the newer gasahol stuff may not be as inert as the old 80-87 avgas was! There are commercially available tank liner compounds, but can't speak to their efficacy - never had to use them. Good luck!
Woody
04-29-2001 17:36:17
I had the same problem on my 1600. Took the tank off and had a local radiator shop clean it and line it. It cost me about $75, did the same thing on my 1850. No more problems.
Paul Stanley
04-26-2001 22:10:13
I went to the archive and found this article I had seen a while ago
