Battery
Jason
04-16-2001 12:48:29
I am researching my bosses, oliver 1255. He currently has two 6 v. batterys, wired in series. Is there a reason for that? Can we replace them with one 24 v. battery?
Mike M (WA)
04-18-2001 08:09:53
 Re: battery in reply to Jason, 04-16-2001 12:48:29
The reason for 2 six volts in series is that you get more amperage than you can find in a single 12 volt. I have used a single 12 volt in my 550 for several years, but am unsatisfied with the cranking power- I'm thinking of going back to the twin 6 volt setup. No matter what you do, get the biggest and best battery cables you can find- the heavy 6 volt cables, with molded terminals.
Jason
04-17-2001 07:24:58
Had a little mix up with my question. What I ment was can we take the two 6v. batterys and replace them with a 12v. battery. (not 24v.)
ROY MI
04-17-2001 07:55:57
 Re: Re: battery in reply to Jason, 04-17-2001 07:24:58
if its setup for 12v yes
Dean
04-17-2001 07:42:44
2 6v batteries wired in SERIES can always be replaced by one 12v battery of sufficient amperage. If they are wired in parallel they cannot.
Jason
04-17-2001 08:20:01
 Re: Re: Re: battery in reply to Dean, 04-17-2001 07:42:44
Thanks for your info Dean. Here are the stats on the batterys I have. "Farmers Choice" type group # FC-1, 640 cold cranking amps. the only physical details I can see is, unlike a car battery the terminals are on opposite corners of the battery. Do you have any idea what 12v. battery I would be looking for? Will it require the 12v. kit thats availible in this forum.
John P.
04-16-2001 17:19:38
Hi Jason, if they are wired in series (+-+-) they are effectively 12-Vdc. If they are wired in parallel (++ --)they are hi-amp 6-Vdc. In any event, don't try 24-Vdc.
ROY MI
04-16-2001 16:26:12
NO two 6v = 12v
one 24v=24v TO MANY V
