Super 55 serial numbers
Nathan Gray
04-04-2001 16:13:29
I just bought a Super 55 diesel and I can't seem to locate the serial numbers. I know that on the larger Super 88's and 77's the serial numbers was just below the dash. Can anyone help me out?
Thanks Nathan Gray
ShepFL
04-05-2001 10:10:03
 Re: Super 55 serial numbers in reply to Nathan Gray, 04-04-2001 16:13:29
Alternate locations - Don't know if this applies to the S55 but on my '67 550 Dsl found no such tag. My s/n is stamped on the boss right below the generator. Stamped vertically.
HTH,
ShepFL
PS - Paul; MOA tractor will be Oliver colors!!!! Have requested photo when complete.
Peter J
04-05-2001 18:29:28
 Re: Re: Super 55 serial numbers in reply to ShepFL, 04-05-2001 10:10:03
That's the engine serial #.
ShepFL
04-05-2001 19:21:27
 Re: Re: Re: Super 55 serial numbers in reply to Peter J, 04-05-2001 18:29:28
My bad. . .
I was thinking engine when I read his post. As to my 550 I have no idea what s/n as no plate. Based on engine casting #s I figure it is a 1967 model.
Thanks for keeping me straight and preventing confusion.
ShepFL
Paul Stanley
04-04-2001 21:01:38
The serial number is on a metal plate attached to the left hand side of the center frame. When you are sitting on the tractor it will be near your left knee. There will be a specification number above the serial number.
Nathan Gray
04-05-2001 14:53:49
 Re: Re: Super 55 serial numbers in reply to Paul Stanley, 04-04-2001 21:01:38
Thanks for the info. I had to do some searching, but I finally found the serial tag, it was hidden under a thick coat of paint. It was a little lower than what you said, it was down by the clutch pedal. Anyway, i found it and it is a 1957.
Thanks again
Nathan
