77 Input Shaft
RCP
04-04-2001 04:44:36
I am working on an Oliver 77, and have the coupling off of the transmission input shaft. The input shaft is worn pretty bad, the splines are worn off about a third of the way through each tooth. The coupler is also bad. I have another coupler that is in better shape, but is there any thing that can be done to help the situation, short of replacing the input shaft? Are there any good sources for new input shafts?
Thanks Rich
jld
04-04-2001 05:15:12
 Re: 77 Input Shaft in reply to RCP, 04-04-2001 04:44:36
Got a new one for 88 from Maibach's. Believe was a good bit less that $100 - was less than I expected.
RCP
04-09-2001 06:43:13
 Re: Re: 77 Input Shaft in reply to jld, 04-04-2001 05:15:12
I talked to Maibachs on Saturday, a new input shaft was about $125 and the coupler was about $65.
