OLIVER 3 POINT HITCH
Jim Bob
04-02-2001 17:05:03
WHAT CAN BE WRONG WITH MY 3 POINT HITCH THE LIFTING ARMS WILL NOT RAISE ..... .IT IS AN OLIVER 1600 DIESEL
larry wolfe
04-03-2001 09:40:36
 Re: OLIVER 3 POINT HITCH in reply to Jim Bob, 04-02-2001 17:05:03
If you have hydrolic preasure,then the linkage to the internal valve may be broken or disconected.The valve can stick too.One other problem is the relief valve for the 3point breaks off (elbow breaks)so the 3point wont work but the rest of the system will work.You will have to remove the top cover and look.Drain the oil first look at linkage and serch the bottem of unit for a loose relief valve.Entire unit must be removed if the valve is laying on the bottem.
