Reverse-O-Torq Transmission
Don
01-11-1999 08:17:37
Where can I find One? Are there repair kits?
This one slips and is in an Oliver 1600 Ind. Loader.
What are they?
Cory Ziegler
01-11-1999 13:52:48
 Re: Reverse-O-Torq Transmission in reply to Don, 01-11-1999 08:17:37
Don, the Reverse-0-Torcs are scarce but handy especially in loader applications. Basically they're just a heavy duty torque converter. What I can suggest is that you consult a good dealer who can give you the answer as to whether or not rebuild kits are available. As an alternative, perhaps you could get the part number for this torque converter since this was almost certainly a part Oliver purchased from an outside manufacturer. Then you may be able to find one somewhere else. Something else to check: Are you sure the converter is slipping or is it the dry clutch ahead of it. May try adjusting this to see if it helps. You might contact Farmersville Equipment Inc. in Ephrata, Pennsylvania at 717-354-2150. They may have a rebuilt Reverse-O-Torc for a 1600.
