18-27 oliver
Russ
03-20-2001 18:08:56
looking for parts for a 1930 oliver 18-27 anyone know of someone with a tractor like this one. Thanks Russ.
Don L.
03-21-2001 16:35:07
 Re: 18-27 oliver in reply to Russ, 03-20-2001 18:08:56
I should have a early 18/27 Oliver coming in for tear down ,when the snow and mud are gone. Don L. at Austin Mn.
ph 507 433 0073
Greg
03-21-2001 09:18:43
Parts can be found, but it is very hard or cost $$$. I also have a 1930 Row Crop Oliver with the single front wheel. At the Oliver show in Macon Missouri in 1997 I got a set of pistons and sleeves. In 1998 I picked up a junk magneto that had a good gear for my magneto at the Portland IN Spring swap meet. In 1999 .... In 2000 .... The point is it will take time and you have to keep your eyes open. I still need to get my cylinder head welded or find a better one than I have.
Good luck searching for parts.
uk row crop
03-21-2001 12:39:17
 Re: Re: 18-27 oliver in reply to Greg, 03-21-2001 09:18:43
I restored my 18-27 in 1997-99, most of the parts I needed came off an oliver 80, which were the magento, seat support, rocker shaft support.
All the sheet metal work and the small fuel tank I had made up using the original for a pattern.
She is now in fine shape and won a cup for best tractor at my local show just after restoration was finnished August 1999. There are only 3 Oliver 18-27's in the UK .
