1650 loader
Bob T
03-18-2001 06:23:47
I am looking for a hydro loader for a 1650
i dont know what loader will fit
jj
03-22-2001 23:25:20
 Re: 1650 loader in reply to Bob T, 03-18-2001 06:23:47
Have new 1650 brackets for Du-Al loader...if you can find a Du-al they are built very well and mount back at the axle...bucket cylinders use a tubular ram and are on underside of arms so they have less/no tendency to tear up cylinders like others can...Westendorfs are mfrd 50 miles So. of here so most guys are running them....
Shep
03-19-2001 13:05:52
The AgCo dealer around here puts the Westendorf loaders on most of the Olivers that he installs loaders on. They are a really good loader, if not a little pricy. Not sure how difficult they are to install, he may have special mounts or something, but it looks real good.
Big Jim
03-19-2001 08:56:33
Bob T,
A 1610 Oliver loader (actually made by Schwartz) will fit right on a 1650 with only minor prefabricating. You will need some flat steel plates and drill 4 holes to match the holes in the frame of the tractor. The back arms of the loader frame will bolt right under the tractor rear axles. I know my descriptions aren't very good, but if you buy a 1610 loader, what I am talking about will become obvious.
Dean
03-19-2001 12:37:29
 Re: Re: 1650 loader in reply to Big Jim, 03-19-2001 08:56:33
Your description is great. That's the setup I have on my 1650 and it works really well.
dwm
03-18-2001 10:12:38
From the same time period and the same brand, the Oliver/White 1610 is the one. Some of these are green, some are painted red after the transition to White. There are any number of others that would work just fine such as the Farmhand mentioned. dwm
John P.
03-18-2001 09:11:37
Have you tried AGCO itself? Their Farm Hand loader may work.
Woody
03-19-2001 09:20:10
 Re: Re: 1650 loader in reply to John P., 03-18-2001 09:11:37
The Dunham Quick tach loader is an excellent fit. We have used one on a 1850, 1600 and a 770. There is some fabrication with the brackets, but not much. The best thing is when you are not using the loader you take it off (5 min ) I just bought a loader for $2000 with two buckets in N.E. Ohio.
