3-speed rebuild cost?
SR
03-16-2001 18:19:11
What kind of money should I expect to get into to rebuild my 3-speed? Underdrive went out last summer and I would like to have it for this summer. I would pull it myself, just need to get it rebuilt. Thanks
larry
03-17-2001 09:15:57
 Re: 3-speed rebuild cost? in reply to SR, 03-16-2001 18:19:11
Can you say whats wrong?
SR
03-17-2001 10:03:31
 Re: Re: 3-speed rebuild cost? in reply to larry, 03-17-2001 09:15:57
Under drive went out. I believe that all the little fingers in over running clutch are shot. Over drive seems to work fine. The oil was changed in it about 35 hours ago with a new filter so it should be ok from that end. The tractor has almost 5000 hrs so I imagine it is about that time.
Dave
03-19-2001 23:09:32
 Re: Re: Re: 3-speed rebuild cost? in reply to SR, 03-17-2001 10:03:31
Regarding fluid in the over under drive what is recommended. Will dextron work?
Dean
03-20-2001 14:18:13
 Re: Re: Re: Re: 3-speed rebuild cost? in reply to Dave, 03-19-2001 23:09:32
It should. I use Mobil 1 synthetic ATF.
Adam
03-18-2001 08:27:22
I did my 2255 last year. It started out as fixing a leaking seal and ended up at close to $3,000 for shafts, disks, spacers, seals, and a variety of other things. It had 4,300 hrs.
larry
03-17-2001 16:26:15
I agree with you the sprage clutch is bad.It will work in low with no oil preasure.The problem about cost is that the shaft the sprages grab onto may need work allso.Many people go ahead and rebuild the whole unit anyway while its out.Its been 20 years since i did a whole rebuild so someone else have comment on cost.
