1900-C??
Reaver
03-11-2001 08:18:37
Came across what was described to me as a 1900-C.
What does the "C" stand for and if there is a "C" is there also an "A" and a "B"?
Thanks
dave
03-11-2001 18:48:03
 Re: 1900-C?? in reply to Reaver, 03-11-2001 08:18:37
There was an "A' and a "B". The 1900-A as tested at Nebraska in 1960 had the "Gemmy" (GM) 4-53 diesel with 89 PTO HP and a six-speed transmission. The "B" was tested at Nebraska in 1962 and had the same engine uprated to 98 HP at the PTO and it had also added the now-familiar partial range power shifting - regular and Hydra-Power Drive for 12 speeds. In 1964 the 1950 was introduced with a few more horsies at the PTO, a little different sheet metal styling, and bigger tires. I have not heard anything about a 1900-"C", though. hope this helps
B A Star
03-12-2001 10:07:07
 Re: Re: 1900-C?? in reply to dave, 03-11-2001 18:48:03
The 1900 tractors were built in the "A", "B" and "C" series. "A" tractors had the checkerboard decal on the engine side panels and the throttle was on the steering column, the last one built was S/N 124 372. "B" series had the metal spear on the engine side panel and the throttle lever still located on the steering column, last one built was S/N 135 430. "C" series had the metal spear on engine side panel and the throttle was moved to the dash as the steering column changed to tilt and extendable. Operators manual form #s are: "A" S1-4-21 issused 6-60. "B" S1-4-38 issused 2-63 and "C" series S1-4-55 issused 1-64. All manuals are identified with the series. Interestingly, the picture of the complete "C" tractor in the manual is of a "B" series, however the manual in the operation section it shows the dash mounted throttle. They musn't have had a picture of the latest model when the manual was printed.
