Oliver 770 Pros cons
GAF
03-07-2001 18:43:58
Considering buying a 770 w/ a loader, haven't seen it yet. Can anyone tell me the HP rating, does it have independent PTO, live hyd.? How can I determine the model year? Are parts still easy to come by? Does the hyd. system have the capacity to handle a loader? Any weak points, what should I look for? Thanks for any info.
D13
03-10-2001 05:34:32
 Re: Oliver 770 Pros cons in reply to GAF, 03-07-2001 18:43:58
Be sure to get wide front and power steering is preferred. I had a NF with PS and it still was a handful with the loader.
One thing to watch out for is the hydraulic pump. They are driven by a live shaft from the engine and are notorious for breaking at the drive area. The fix is a pain in the ear as the shaft has to be pulled. One thing to lookk at is the pipe connections to the bottom of the pump - these tractors were not equipped with breakaways and whan you lose a plow, the hoses were yanked out of the pump. THis very often would break the drive housing at the bottom of the pump (I personally have seen 4 tractors with this condition). A way to check for a cracked housing is to pull the trans fill plug - if the housing is cracked it will leak into the trans, the trans will be overfull, and the trans oil will be lighter tan from the 10w or reddish from the trans-hyd fluid. THe original trans lube is a heavier gear oil.
Other than that these are a heck of a machine! A 3 point conversion is about $650 complete with cylinders, and after that there's about nothing you can't do (except mow the lawn - too heavy).
Jake in NY (good lord, I'm the expert?!?!?!
03-08-2001 21:37:04
third party image
Our 770 is a later model with about 40 hp. It handles the loader (Oliver 1610) better than any of our other tractors that we've put a loader on, so great hydraulics. Hydraulics and PTO are both independent. Um, weak points, hmm. We've had clutch problems for years but that might have something to do with it being a loader tractor and at least two bad clutch jobs so we decided to just go til she quit and it's been about 14 years or so and she still hasn't quit. Other than that, I can't think of any real problems with it. It has a whine in the rear end which apparently is just a quirk of the model.
Oh yeah, you have to pay extra to get the bent muffler. lol.
Jake
Mike M (WA)
03-08-2001 08:32:55
If thats the one in the photo ads with the IH loader, I'd jump on it- it looks like a steal. Haven't seen it, of course- I'm planning to buy a tractor in the midwest this spring, and the 770 would probably make the most sense- but I can't seem to get the roar of the Cockshutt 570 Super out of my head. . . Anybody got a hot deal on one?
Shep.. Talk to Jake in NY
03-08-2001 06:50:00
Talk to Jake in NY, he has a 770 just like you are talking about in the oliver photo gallery here on YT Mag. He could tell you how his has been doing.
Huh? This was not a post by me (shep)
03-08-2001 07:20:55
 Re: Re: Oliver 770 Pros cons in reply to Shep.. Talk to Jake in NY, 03-08-2001 06:50:00
Perhaps you were thinking GAF and said Shep?
I can't help you since I don't own a 770, only Oliver I own is a 67' 550 Dsl. At one time I was looking for a drawbar to modify for my 550.
Greg Sheppard aka Shep
Sanderson, FL
Shepherd -- OOppppsss
03-08-2001 08:09:47
 Re: Re: Re: Oliver 770 Pros cons in reply to Huh? This was not a post by me (shep), 03-08-2001 07:20:55
I was commenting that he needed to talk to Jake in NY. Sorry I had just shortened my handle a little from Shepherd. Did not mean to step on ya Greg.
ShepFL
03-08-2001 08:42:13
 Re: Re: Re: Re: Oliver 770 Pros cons in reply to Shepherd -- OOppppsss, 03-08-2001 08:09:47
Shepherd -
No issue here. I will just begin using ShepFL as we have the same last name it is very easy to use Shep.
Most of my friends refer to me as Shep hence my use here of the same. ShepFL is ok by me and you can continue using Shep. Thanks for all I have learned from you and those "brute" Olivers you have.
Greg aka ShepFL
Scott Green
03-08-2001 04:44:06
I have a Oliver "770" with a "New Idea" loader on it. Exellent tractor. Just PRO's. Sorry , no Con's. I'll bet your not sorry to here that. It has everything you mentioned.
jerry gerthofer
03-09-2001 15:15:17
 Re: Re: Oliver 770 Pros cons in reply to Scott Green, 03-08-2001 04:44:06
I have a 770 they were a very good built tractor just had the engine all rebuilt it mine a year ago run 40 more year
