WFE
03-03-2001 16:28:52
Was reading the posts below on the 1950-T and thought it warranted further discussion, or in this case, defense. The turbocharged 310 cu. in. Oliver/Waukesha engine used in the 1950-T was a great engine in performance and fuel economy and could live a long time if they were built properly. Biggest problems related to poorly balanced crankshafts, weak rod bolts, and two-piece pin bushings. When rebuilding one, all these can be rectified by: having crank balanced, replacing rod bolts with new and torquing only once, and replacing pin bushings with new one-piece design. Pin bushings tended to cause spun bearings, rod bolts and poorly balanced cranks tended to break rods and the cranks themselves. When these items are addressed during rebuild, the engine will be durable. One must keep in mind, however, that lugging the 310 below rated rpm of 2400 for extended periods is not good for it. Keep rpms up to 27-2800 to keep load on components light. As for head gaskets, the head bolt spec. was a bit conservative so we can exceed the book torque spec. by 15-20 ft. lbs and gain significantly in head gasket reliability. Also helps to use a gasket adhesive on head gasket during installation. And of course, the head and block surfaces must be true. Some 310s had a tendency for their sleeves to settle into block. This requires shimming or block decking to rectify during engine rebuild. Doing these, with perhaps a few other minor points, will make a good strong 310. Regarding oil loss through stack, probably leaking through turbo, indicating the tractor probably needs a rebuilt turbo, about $700. Good oil pressure is important so, to the gentleman looking at the 1950-T on the auction sale, look at oil pressure. If good, then bring engine up to speed and feel for excessive vibration. What is excessive? Well, if steering wheel is vibrating such that your hand tingles, probably a bad sign. The 310 from the factory was kind of a toss-up whether or not you got a good one or a bad one. But they could be a fine engine.
