Hyd. pump
Brian
02-26-2001 15:44:14
Hello,
I have a Vickers Power Pack Hyd.Pump(PK11 5100 D12 S9) off of what I was told was an Oliver. The questions I have are many but hopefully someone can answer them.
What is the GPM flow of this pump?
What is the RPM for the pump shaft(It has a belt pulley on it)?
What is the working PSI for this pump?
Are gaskets available for it?
The reason I ask is I was given this pump and am looking to build a log splitter if it will work...
Thank you for your time..
Brian
