OIL LEAK ON 77
HAYSAM
02-26-2001 11:03:02
TOOK MY 77OUT FOR A SHAKEDOWN AND A TANK OF GAS RUN IT ABOUT 8 MILES THE NEXT DAY HAD BIG SPOT OF OIL UNDER TRACTOR. drained oil about 4gal was not over full
Joe Hill
02-28-2001 18:12:59
 Re: OIL LEAK ON 77 in reply to HAYSAM, 02-26-2001 11:03:02
Sounds like Vern hit the nail on the head. Good luck and keep them old Olivers running.
HAYSAM
02-26-2001 16:56:24
SORRY I DID NOT EXPLAIN MORE IT WAS THE REAR END AND THE TRANS.
vern in ne ks
02-26-2001 13:06:22
I'm going to make several assumptions here for lack of more information. I'm going to assume you drained all this oil from the rear end/transmission because I don't think you could get 4 gallons in the crankcase to start with. With this thought in mind, I think all the extra oil came from the hydraulic system, also assuming this tractor has one. The seals have went out of the hydraulic pump allowing this oil into the final drives. If you check, your hydraulic system is probably empty.
Jerry B
02-26-2001 12:18:27
????? ????? You drained out 4 gallons of engine oil and it WASN'T OVER FULL????? ????
